i7 860 or AMD Phenom II x4 965 Black Edition
11782 Views 37 Replies 23 Participants Last post by  MrAlex
5
I have a very bad system right now and I am upgrading it
There are two processors that really stand out to me:
I7 860- $229
AMD Phenom II x4 965 BE- $195
I have to buy a new board (Intel and AMD board both $100), but if I get the intel I would have to get new RAM because it does not support DDR2 memory ($100 for the RAM).
If I get intel:
I7 860- $229
Motherboard- $100
RAM- $100
TOTAL: $429
If I get AMD:
Motherboard- $100
TOTAL: $295
As you guys an see there is a significant difference between the two costs. What I am asking you guys is, "Is it worth it?"
I will be using the computer 96% gaming and 4% web surfing.
I would much rather have an Intel processor and motherboard (Intel owns!
) but unfortunately the significant cost difference is a problem for me. My parents told me that they will pay $300 of the parts, but I will have to pay for the rest. I currently have $600 (I worked hard for it!
) and I would prefer not to dip out of my savings. I WILL if there is a significant difference in performance. Enough of my story
, so now I ask you, "Which is better the i7 860 or the AMD Phenom II x4 965 BE"?
UPDATE: For those of you that are curious what motherboards I'm getting:
Intel- Biostar TP55 Socket 1156 P55 ATX Motherboard
AMD- Biostar TA790GXB A2+ 790GX AM2+ ATX Motherboard
1 - 20 of 38 Posts
There really is no advantage for getting the i7 860 over the i5 750, unless you need hyperthreading. The significance hyperthreading on an already blazing fast quad is nonexistent in gaming, unless you got something that takes advantage of 8 cores
. Check this out, i5 750 with OCZ Gold 4GB DDR3 set for $233. Correct me if I'm wrong, but I think the i5 overclocks better too
. Total with the motherboard you picked it will come to $333 + shipping.
i'm considering switching to the amd just because of how hard it's been for me to find a bloodrage at all.
Originally Posted by LemonSlice View Post
There really is no advantage for getting the i7 860 over the i5 750, unless you need hyperthreading. Check this out, i5 750 with OCZ Gold 4GB DDR3 set for $233. Correct me if I'm wrong, but I think the i5 overclocks better too
Yes, but I mainly chose the i7 860 over the i5 750 because of the clock speed (2.8 vs 2.66) would this increase of clock speed make a difference
I'm thinking foxconn is getting ready for a revised bloodrage, not sure though, maybe there just selling out quick.
I'm a big fan of the i5/i7, but I'm going to ask that you not purchase either due to the fact that the i7 you want is on the 1156 boards. That socket is not going to last long at all. I can't figure out why they did that.
Article on this exact point.
The link is to the point.
Really? I didn't know that (Sry I don't have much computer hardware knowledge compared to the others on overclock.net
), so should I get the AMD Phenom II x4 965 BE?
Do you intend to overclock? I believe it would be a walk down 2 stairs to overclock 2.66 up to 2.8.
OP, also post the motherboards you are looking at buying. The MB is thw backbone of your system, and is a critical component which should be researched. Can you give any more info other then $100 boards?
I just added a link to back up my claim. The 965 is a great choice, but if you have a bit extra (I know you have a budget), go 1366 on the i7.
Good point, I WILL be overclocking (not very good at it so I'll be overclocking it slightly), but wouldn't I be better off with AMD if I was focusing on clock speed?
just updated the post
Don't quote me on this but Intel chips are faster clock for clock (faster per mhz) and get higher clocks (with the right cooling).
The LGA1156 board you are considering does not look very good.
The AM2+ board you are considering isn't the best one you can get for the price. This board is better.
http://microcenter.com/single_produc...uct_id=0315788
OP, I dont know if you can order from newegg, but this board would be a great choice for an i5 build:
ASUS P7P55D PRO LGA 1156 Intel P55 ATX Intel Motherboard $129
If you plan to only run 1 video card, check out this one:
ASUS P7P55-M LGA 1156 Intel P55 Micro ATX Intel Motherboard $81
Do NOT go with Biostar.
Why?
Why?
I know it's quite cliché, but you really do get what you pay for. Their customer service/warranty/quality is junk. You'd be way better spending a tiny bit extra for a known brand.
dood ever heard of overclocking?
I understand where you are coming from, but for most of us here this really wouldn't be an issue would it? To be clear, it really isn't an issue for me personally, while I could see it as an issue for someone else. Then again, when I do new builds, I tend to completely change platform anyway (see the AMD in my sig, and now I'm planning on going to the i5 750).
I think the i5 750 is a FANTASTIC chip for a gaming machine given it's ability to hit 4.0 ghz, and the chip's price point. Especially at Micro Center (I know, not everyone lives near one, but it's worth mentioning) where it's only $149! At a price point CHEAPER than the 955/965, it outperforms either of those in games because of turbo mode in most instances I've seen online so far.
For people who are going to build the machine, and not worry about a platform change for another couple of years, this platform is perfect for gaming. If you can live with the 8x/8x PCIex16 lanes, and the difference here is highly negligible, then why NOT consider this chip?
This chip is my hands down choice currently for my upgrade.
1 - 20 of 38 Posts
