1 - 8 of 8 Posts
4kfan
it looks fine.. i7s cores temps are always out of wack some times by 10c.
Discussion Starter · #6 ·
I could be doing anything, but since I moved from the Zalman CNPS10X Extreme, to the much smaller H50, I haven't had a problem. Maybe the pressure from the Zalman caused the cpu to shift or something? It happened really randomly. Mostly when I had the internet open, but sometimes for hours nothing would happen. I ran 3 different liveCD virus checks, and also used seatools just to be safe and it all pased. mem test passes also.
Wierd. Well as long as its not doing it anymore its fine.
You should try overclocking. no point to an h50 if you dont overclock
1 - 8 of 8 Posts
