I am upgrading from an i3-350 to an i7-870 on a Biostar TH55B HD motherboard. When I install the i7 no display comes up and the board beeps twice (I am assuming this is the boot block beep) and then 8 times (Post BIOS Beep). In the manual the two beeps for the boot block mean "AIMBOOT.ROM" file not found in root directory of diskette in A: ( I have no clue what this means) and the 8 beeps mean display memory error for system video adapter.
When I re-install the i3 all problems go away. Is there a setting in the bios I need to change before installing the i7? I am at a lost and any help would be great.
When the i7 was installed I reseated everything, took all pci cards out, and even started the computer without memory to see if I got a different error (I did).
