ASUS P7P55D-E LX, P55, Socket-1156
Intel Core i7 Quad Processor i7-870
Kingston DDR3 HyperX 1333MHz 8GB
Noctua NH-D14 CPU Cooler
Currently i'am running the CPU @ 3.81Ghz, 173 BCLK, CPU Ratio 22.0 and it's stable, idle 28-30C, max load 59-61C. I'am looking for a good, stable, build with low temps. The setup is stable with my memory clocked down to 1041Mhz on auto, but when i clock it manually up to 1384Mhz the system crashes after 5min of testing with Blend in Prime95. So my question is what should i adjust now to get it stable again ? Or if you got any other advice on a better O.C just say it
BSOD after 5min, memory dump stops at 55
CPU Ratio Setting - 22.0
BCLK - 173
DRAM - DDR3-1384Mhz
QPI - Auto (according to CPUZ QPI Link is 3124.27Mhz)
Memory timings set manual then the timeings are 9 10 10 25 at 1384Mhz Clock
When memory is set to auto with clock 1041Mhz the timeings are 6 7 7 19
Differential Amplitude - Auto
Clock Skew - Auto
CPU Voltage Mode - Manual
VCore - 1.29375v
IMC - 1.30v
DRAM - 1.64v
PLL - Auto
PCH - Auto
DRAM Data REF Voltage on CHA - Auto
DRAM Data REF Voltage on CHB - Auto
C1E - Enable
Speedstep - Enable
LLC - Enable
Spread Spectrum - Disable
BCLK - 173
DRAM - DDR3-1384Mhz
Clock Skew - Auto
VCore - 1.29375v
IMC - 1.30v
DRAM - 1.64v
PLL - Auto
PCH - Auto
C1E - Enable
Speedstep - Enable
LLC - Enable
