As the title states, my new 8700k is being detected as a 4 core 8 thread CPU by all monitoring programs such as CPUZ, HWInfo, and even Task Manager. Cinebench also reports it as 4 cores 8 threads and I get a pitiful score of 818, when all reviewers put the 8700k at around 1400.
So I believe this is a mobo issue, as there are other things not working with it. My Memory settings in the BIOS works, but nothing else. I can try to OC, and it doesn't work. I can try to limit the CPU to 2 cores, doesn't work and so on. Essentially nothing but the memory settings and fan settings stick when going into Windows. One weird thing is, when I DO try to OC and keep Vcore on Auto, I can see in CPUZ that it is applying that extra voltage(going from 1.0-1.1v stock to 1.35v) to the CPU but the clock speeds are all being reported as 3.7 still across the 4 cores being detected.
Even when resetting everything to defaults, Turbo Boost doesn't function properly. All the cores stay at 3.7Ghz all the time. They don't down clock when idle and no core boosts beyond that when under load.
What makes this even more bizarre, is that while Cinebench clearly shows my CPU is under performing, I am seeing gains in the few games I've tested. I've been playing Mass Effect: Andromeda and before on a 7700k at 4.8Ghz, I would often get bad drops in certain parts of the game, but now I've gained about 20-30 fps in those severe situations, and overall gained about 5-7 fps in most scenarios. I haven't tested many other games but the ones I have, they perform better than before.
I'm on the latest 0420 BIOS, and I tried updating from the launch bios to 0419 before this and that changed nothing.
My full specs are:
i7 8700k cooled by EK Predator 240
ASUS Z370-F
Zotac GTX 1080 Ti Amp Extreme
32GB TridentZ RGB 4133Mhz(running at 3200Mhz currently)
Seasonic Prime Titanium 850w
2 NVME M.2 SSDs and 2 SATA 2.5" SSD's
Creative AE-5 Sound Card
Let me know if there's any more information I can give, I don't think I'm forgetting anything but I could be.
I've ordered a cheap Z370 board from Newegg to better test if this is an issue limited to my current motherboard, or an actual CPU fault. So that will be more telling, but for now, any help would be appreciated.
My full specs are:
ASUS Z370-F
