I am no expert but I have read in posts that are stickied here at OCN that there are issues with the CPU Ratio 20 for our CPU, try CPU ratio 21.
Originally Posted by )v(aster ![]() You seem to be having the same issue I am, I am currently stable at BCLK of 191x21 @4.0GHz, but like you I am trying to reach BCLK of 200x21 @ 4.2GHz to get the full MHz my memory is rated for. I have tried many setting leading up to my last try with exactly the same voltages and settings you listed with no success. The above is from my post for help. I hope you find my current stable settings for [email protected] usefull for now, which would get you just shy of your memorys rated settings. I will let you know if I can get it stable and what worked for me, if you get it stable at BCLK 200 before me then please post your stable results and settings for BCLK 200. I wold greatly appreciate it! ![]() |
Originally Posted by jshay ![]() 1.3vcore isn't that high. Many D0's can't do 4.0ghz at 1.3vcore, heck mine can't either. I would raise it since you have quite a bit of headroom on that. |
