1 - 20 of 38 Posts
Knows the Song of Time
Originally Posted by TeenAgeReneGade2316
i used to get load temps of 159F and i realize that i have a diff cpu but after i lapped it, my load temps are only 114F
So the irony of this statement is thus:
We silly Americans don't use the metric system. Most of us can't convert centigrade to fahrenheit in our heads and we don't know the difference between a kilometer and a mile. However, when it comes to PC language, I can't really think of CPU temps in fahrenheit. This is nothing against you, Teenagerenegade, I just never realized it until you posted your temps.
Crazy.
Crazy.
ok ok ill do it for you, 70C load before and 45C load after
Temps are a little high given your voltage, probably can bring them down a bit by reseating the cooler (assuming it is the one in your sig). But they aren't too far off, the i7s run hot
Iconoclast
Originally Posted by kaifudin
Dear OC'ers
I overclocked my 920 to 3.5ghz and its stable.
The question is, is this temperature high or is it normal?
Which test is that? large FFTs or Blend?
What are your ambients?
25C drop in temps from lapping alone is not possible. Something else must have changed.
not possible....really? well call the guiness book cause it happened, i even made a thread about it
Discussion Starter · #13 ·
Thanx for the answer. How can I reseat the cooler? How can I bring temps down? I have a Cooler Master V8 installed.
Temps are a fairly high bro, my chip never gets above 64*C on prime with HT on even at 4.0ghz 1.29v vcore with my TRUE and 38mm ultra kaze, you might try to reseat your cooler and see if that helps, you also could have just got a chip that runs pretty hot, try the reseat and let us know how it goes.
at full load overclocked to 3.8ghz an i7 has around 250w of energy going through it creating A LOT of heat, your temps aren't bad but I wouldnt want to go over 80-85 full load regardless of how long you are stress testing for
reseat and a good TIM like mx-2, Mx-3, icd7 will also help your cause
Haha. I hope I didn't offend you or anything. I was just making a statement of how it's ironic that I seem to forget we are not on the metric system when referring to CPU temps.
I looked at your post first and stood aback, thinking your temps had hit above 100, lol.
Just pull it back off and clean up the old stuff, then put you a squirt of thermal paste right in the middle about the size of a peice of rice, set your cooler down on it and spin it 45* to the right (it don't really matter which way), and spin it back into mounting position, clamp it back down and boot up to see what the temps look like... What thermal paste are you using? I highly reccommend OCZ Freeze, OCZ Freeze = better temps and no cure time for the thermal paste!
What stepping is your processor, by the way? The C0 stepping will run hotter than the D0 if I'm not mistaken (as it requires more voltage to stay stable). I also didn't see what voltage you're running in the first place.
Let us know both these things so we can narrow down your options.
1 - 20 of 38 Posts
