1 - 3 of 3 Posts
Other peoples BIOS settings won't help you on Your Board & Your Chip.
There are known "approximate" settings that are likely to work with certain configurations, but at the end of the day - you're best off tweaking them yourself.
http://www.overclock.net/intel-cpus/...920-930-a.html
http://www.evga.com/forumsarchive/tm.asp?m=100494809
^ These will help get you started.
These are some common BSOD errors and their likely cause.
0x101 = increase vcore
0x124 = increase/decrease vcore or QPI/VTT...have to test to see which one it is
0x0A = unstable RAM/IMC, increase QPI first, if that doesn't work increase vcore
0x1A = likely related to memory; loosen timings/frequency and/or raise voltage
0x1E = increase vcore
0x24 = increase vcore
0x3B = increase vcore
0xD1 = QPI/VTT, increase/decrease as necessary
0x9C = QPI/VTT most likely, but increasing vcore has helped in some instances
0x50 = RAM timings/Frequency or uncore multi unstable, increase RAM voltage or adjust QPI/VTT, or lower uncore if you're higher than 2x
0x109 = Not enough or too much memory voltage
0x116 = Low IOH (NB) voltage, GPU issue (most common when running multi-GPU/overclocking GPU)
1 - 3 of 3 Posts
