Originally Posted by XFreeRollerX
How good is this motherboard in terms of cooling
I might get this P6T Deluxe only if the standard motherboard cooling is good enough to where I will not need a freaking LCS for the motherboard.
Can you comment on temperatures of the motherboard (include your ambient temp and what your setup is too) please
my ambient is 21degrees celcious, and with the stock cooling in my antec 1200 case the northbridge idles at 32-35 degrees celcious, and it loads around 50 degrees. I put an 80mm fan blowing on the north bridge and now it only loads into the low 40's. like i said the current bios doesn't allow you to remove the over current protection, so i would try to find one that does if you aren't buying an extreme.
Originally Posted by bowman
So, it should be arriving some time this week..
1.55V, seriously? That's pretty good. Should enable over 4GHz on the stock cooler even..
i doubt it, my chip runs pretty hot. low 60's on load and that's with watercooling at 3.88 Ghz. Before they moved the memory controller onto the chip you were limited by voltage, but now it seems we will be limited my temps again, or maybe i just seated my waterblock wrong, who knows.
