Hello everyone;
This is my first time posting in Overclock.net.
Need some advice and suggestion on i7 920 D0 overclocking.
Here is my brief overclock setting:-
CPU: i7 920 D0 @ 4.2GHz; HT Off.
Motherboard: Rampage III Extreme.
Cooler: Swiftech Apogee XT; Feser XChanger 360; MCP-655 Pump; 2 Fans Push, 3 Fans Pull.
Temperature: Average 77 Celsius (7 Hours Prime test); Room Temp: 26 Celsius
Thanks in advance
Here is my complete BIOS settings:-
Target CPU Frequency: 4200MHz
Target DRAM Frequency: 1603MHz
LN2 Mode: Disabled
QPI Loadline Calibration: Disabled
Ai Overclock Tuner: Manual
OC From CPU Level Up: Auto
CPU Ratio Setting: 21
CPU Turbo Power Limit: Disabled
CPU Configuration:-
C1E Support: Disabled
Hardware Prefetcher: Enabled
Adjacent Cache Line Prefetch: Enabled
MPS and ACPI MADT ordering: Modern ordering
Intel(R) Virtualization Tech: Enabled
CPU TM Function: Enabled
Execute Disable Bit: Enabled
Intel(R) HT Technology: Disabled
*Active Processor Cores: All
A20M: Disabled
*Intel(R) SpeedStep(TM) Tech: Disabled
Intel(R) C-STATE Tech: Disabled
BCLK Frequency: 200
PCIE Frequency: 100
DRAM Frequency: Auto
UCLK Frequency: Auto
QPI Link Data Rate: Auto
Memory Recheck: Disabled
Memory Configuration Protect: Disabled
DRAM Timing Control:-
1st Information: 9-9-9-24-6-88-12-8-24-0
2nd Information: 1N-64-67-67
3rd Information: 6-6-18-10-10-10-7-6-4-7-7-4
CPU Differential Amplitude: Auto
CPU Clock Skew: Auto
IOH Clock Skew: Auto
Digi+ PWR Mode: T-Balanced
PWM Volt. Control: Auto
Load-Line Calibration: Enabled
CPU PWM Frequency: Auto
Extreme OV: Disabled
Extreme OC: Auto
CPU Voltage: 1.37500
CPU PLL Voltage: 1.90800
QPI/DRAM Core Voltage: Auto
DRAM Bus Voltage: 1.654
DRAM REF Voltages: All Auto
IOH Voltage: Auto
IOH PCIE Voltage: Auto
ICH Voltage: Auto
ICH PCIE Voltage: Auto
CPU Spread Spectrum: Auto
PCIE Spread Spectrum: Auto
Thanks in advance
LN2 Mode: Disabled
CPU Configuration:-
A20M: Disabled
BCLK Frequency: 200
PCIE Frequency: 100
Extreme OC: Auto
IOH Voltage: Auto
ICH Voltage: Auto
