Greets everyone,
I am having trouble getting my 4.0 OC stabilized. I used the Guide to Overclocking 930 to 4.0 and used the quick and dirty vcore boosting method for 4.0.
So I am running the following settings:
CPU Volts - 1.25
IOH - 1.2
ICH - 1.2
vdimm - 1.65
CPU PLL - 1.88
QPI/Uncore - 1.35
Bclk - 191
Multi - 21
Speedstep OFF, C1E Off, HyperThreading off
Everytime I run Prime 95, I get BSOD error code 124 within 1 minute. This has to do with QPI as far as I can tell, I tried upping it to 1.375 (max safe limit with Vdroop, apparently), I tried lowering to 1.325, 1.3 - all produced the same 124 code.
Looking for some help here! Not sure what to do to get this one stable.
Method #3: Quick and dirty vcore boosting.
Set your ioh and ich to 1.2, your vdimm to 1.65, your cpu pll to 1.88, and your qpi/uncore to 1.35. Set Bclk to 190/191 or 210/211 and multiplier to 21 and 19 respectively.
The d0 chip usually hits 4.0 in the vcore range of 1.175 and 1.25 try those voltages until you find whats right for your chip.
CPU Volts - 1.25
IOH - 1.2
ICH - 1.2
vdimm - 1.65
CPU PLL - 1.88
QPI/Uncore - 1.35
Bclk - 191
Multi - 21
