How good is the overclock?
  • Good overclock
    Votes: 4 66.7%
  • Average
    Votes: 2 33.3%
  • Bad overclock
    Votes: 0 0.0%
1 - 7 of 7 Posts
Hi guys id just like to share my overclock on my i7 930.
And see how good the actual overclock is and i hope you guys can share your progress on here to compare.
Ran prime 95 for 70minutes
and ran Intel Burn Test 20times
Temps are;
idle = 41c
maxload = 70-74c
my system specs are;
CPU - i7 930 @ 4.01 Ghz
Motherboard - Asus P6X58D-E
Graphics Card - GTX 460
Memory - 6GB DDR3 1531 Mhz
Memory Cooler - XCILO Xtreme Copper Memory Cooler
Power Supply - EZcool Tornado 800W
NIC - Bigfoot Networks 2100
Case - CM Storm Scout
4 case fans - 140mm Front intake & 120mm Front intake, 120mm Back outtake, 140mm Top outtake
Additionals;
2x Red Cathode lights
1x Blue flashing cathode light
bios settings
Ai Overclock Tuner.....................[Manual]
CPU Ratio Setting......................[21.0]
Intel(r) SpeedStep(tm) Tech............[Disabled]
Xtreme Phase Full Power Mode...........[Enabled]
BCLK Frequency.........................[191]
PCIE Frequency.........................[100]
DRAM Frequency.........................[DDR3-1531MHz]
UCLK Frequency.........................[3063MHz]
QPI Link Data Rate.....................[Auto]
CPU Voltage Control....................[Manual]
CPU Voltage............................[1.26250]
CPU PLL Voltage........................[1.80]
QPI/DRAM Core Voltage..................[1.21875]
IOH Voltage............................[1.14]
IOH PCIE Voltage.......................[1.50]
ICH Voltage............................[1.20]
ICH PCIE Voltage.......................[1.50]
DRAM Bus Voltage.......................[1.64]
DRAM DATA REF Voltage on CHA...........[Auto]
DRAM CTRL REF Voltage on CHA...........[Auto]
DRAM DATA REF Voltage on CHB...........[Auto]
DRAM CTRL REF Voltage on CHB...........[Auto]
DRAM DATA REF Voltage on CHC...........[Auto]
DRAM CTRL REF Voltage on CHC...........[Auto]
Load-Line Calibration..................[Enabled]
CPU Differential Amplitude.............[800mV]
CPU Clock Skew.........................[Delay 300ps]
CPU Spread Spectrum....................[Disabled]
IOH Clock Skew.........................[Auto]
PCIE Spread Spectrum...................[Disabled]
C1E Support............................[Disabled]
Hardware Prefetcher....................[Enabled]
Adjacent Cache Line Prefetch...........[Enabled]
Intel(r) Virtualization Tech...........[Disabled]
CPU TM Function........................[Enabled]
Execute Disable Bit....................[Enabled]
Intel(r) HT Technology.................[Enabled]
Active Processor Cores.................[All]
A20M...................................[Disabled]
Intel(r) C-STATE Tech..................[Disabled]
Special Thanks to xmisery for sharing hes settings on overclocking sure helped me alot
Some screen shots;
http://img375.imageshack.us/i/coretmp32.jpg/
http://img697.imageshack.us/i/cpuzqi.jpg/
http://img823.imageshack.us/i/realtemp.jpg/
Discussion Starter #4
Originally Posted by NitrousX View Post
You should post a cpuz screenshot. Is your overclock prime stable?
hey bud for some reason when i posted the links up it didnt show so ive pasted the links instead not sure why the images aint showing up
Discussion Starter #6
Originally Posted by Nemesis429 View Post
Run LinX 20 times, linx is very sensitive.
i think its pretty stable cause ive ran IBT through 20times set to high
and ive read that, doing so is equivalent to running your computer for 3 days.
No...
20 runs of LinX/IntelBurn doesn't determine 24/7 stability in the slightest. The only thing it determines is that your CPU was stable for those 20 passes (just over an hour or so)
Who's to say that it doesn't crash after that hour? or even worse, crash while you are doing something important with less CPU utilisation.
To get a better judgement of overall 24/7 stability you want to be stressing the CPU far longer AND be using more than one method of stress testing too.
This is what I and many others here would consider a 24/7 stable overclock.
Prime95:
12 - 24 hours of Small FFT's
12 - 24 hours of In-Place Large FFT's
12 - 24 hours Blend
LinX/IntelBurn (With the latest Linpack Libraries):
100 runs using the maximum available RAM with nothing running in the background. (This is includes disabling various Windows services such as Windows Update and shutting down any Anti-Virus monitoring software.
Memtestx86+:
10 passes or a 24 hour run
MemTest:
Setting to run with the maximum available RAM with no background processes running (see above)
If your system can pass every single one of those tests then you are looking at a true 100% stable overclock, and there is a good chance it will be. If it can't then it's almost certainly unstable somewhere and there's no two ways about that.
I'd rather know that my system isn't going to crash than actually have it happen when I least expect it, just because I thought it was stable.
1 - 7 of 7 Posts
