1 - 8 of 8 Posts
Ai Overclock Tuner.....................[Manual]
CPU Ratio Setting......................[21.0]
Intel(r) SpeedStep(tm) Tech............[Disabled]
Xtreme Phase Full Power Mode...........[Enabled]
BCLK Frequency.........................[191]
PCIE Frequency.........................[100]
DRAM Frequency.........................[DDR3-1531MHz]
UCLK Frequency.........................[3063MHz]
QPI Link Data Rate.....................[Auto]
CPU Voltage Control....................[Manual]
CPU Voltage............................[1.26250]
CPU PLL Voltage........................[1.80]
QPI/DRAM Core Voltage..................[1.21875]
IOH Voltage............................[1.14]
IOH PCIE Voltage.......................[1.50]
ICH Voltage............................[1.20]
ICH PCIE Voltage.......................[1.50]
DRAM Bus Voltage.......................[1.64]
DRAM DATA REF Voltage on CHA...........[Auto]
DRAM CTRL REF Voltage on CHA...........[Auto]
DRAM DATA REF Voltage on CHB...........[Auto]
DRAM CTRL REF Voltage on CHB...........[Auto]
DRAM DATA REF Voltage on CHC...........[Auto]
DRAM CTRL REF Voltage on CHC...........[Auto]
Load-Line Calibration..................[Enabled]
CPU Differential Amplitude.............[800mV]
CPU Clock Skew.........................[Delay 300ps]
CPU Spread Spectrum....................[Disabled]
IOH Clock Skew.........................[Auto]
PCIE Spread Spectrum...................[Disabled]
C1E Support............................[Disabled]
Hardware Prefetcher....................[Enabled]
Adjacent Cache Line Prefetch...........[Enabled]
Intel(r) Virtualization Tech...........[Disabled]
CPU TM Function........................[Enabled]
Execute Disable Bit....................[Enabled]
Intel(r) HT Technology.................[Enabled]
Active Processor Cores.................[All]
A20M...................................[Disabled]
Intel(r) C-STATE Tech..................[Disabled]
Discussion Starter #5
Well i tried those settings just for the hell of it and I got a message upon bootup:
Overclock failed press F1 to reconfigure...
Any thoughts?
My settings right now are:
BCLK Frequency.........................[133]
DRAM Frequency.........................[DDR3-1600MHz]
UCLK Frequency.........................[3050MHz]
Discussion Starter #7
Still no luck.
I tried CPU Voltage at 1.3 and at 1.35 doesnt work.
My settings are now same as my most recent reply above but CPU Voltage at 1.3 and BCLK Frequency back to 133.
BCLK times Multi = clock
Update ur BIOS to 1002!
Then use exactsetting I gave u....
191x21!
and if it gives u F1... do it.. and apply the settings
Boot
and Use RealTemp + LinX for testing...
if it passes 20+ @Maximum memory - it;s OK.
and u can lower CPU V and QPI/DRAM
1 - 8 of 8 Posts
