i7 Board
657 Views 17 Replies 8 Participants Last post by  litho
Hey guys I need some advice on which i7 board is the best has to have 6ram slots and can't be over $270sh any suggestions would be great. I was looking at the gigabyte GA-EX58-UD4P what do you guys think is it the best in the price range.
1 - 18 of 18 Posts
If you can get them for cheaper, one of these one be great:
http://www.newegg.com/Product/Produc...82E16813188039
http://www.newegg.com/Product/Produc...82E16813131346
If not, that Gigabyte looks pretty good, but I haven't heard much about it.
EVGA X58. Same as the one for 299 except warranty is 2 years. Comes out to be 249 after 20$ MIB
is the UD5 worth the extra $30 if I am only going to quad sli ?
Yes. Look at the cooling component.
the ud4p runs its pcie like this
x16
x16 + x16
x16 +x8 +x8
so if you are going to run 3 cards ud4 is probably not the choice (even though you probably couldnt detect the difference) otherwise its an awesome board, I have no complaints
er maybe im a bit behind the times here but quad sli with only 3 avaliable pci-e slots?
pretty sure you need the evga "classified" board, if it is still classified, to do quad sli?
I own the evga board linked above, and i am very happy with it. I believe it will do trisli in a x16 x16 x8 config but i have not purchased extra cards yet.
It blocks one of the pci-e x1 slots if am not mistaken and I need that for a tv tuner that I already have which is pci-e x1
also while am at it would the XIGMATEK Dark Knight be suffiecent in cooling the 920 at say 3.6~3.8ghz ? if not would the v8 be much of a diffrence ?
He meant quad sli as in 2 dual GPU cards, like the GTX295 or 9800GX2
Quad sli is sli-ing 2 video cards that each have 2 gpu's, such as the gtx295 or the 9800gx2.
Thats what I was thinking, but I didn't want to jump to conclusions, I left my mat at the office.
ok. The XIGMATEK Dark Knight is fine. If you need tri sli board, you need UD5. See wimcle's post above.
quad sli is two gtx 295's sli'd
It is blocked on the ud4p as well...
so if I don't need tri sli and need the pci-e x1 for tv tuner. The ud4p would be my best choice. And the xigmatek like does it compete with the cooler master V8 ?
UD4P is a good choise in this case and Xigmatek is slightly better than V8.
Thanks for all your help
1 - 18 of 18 Posts
