Originally Posted by compuman145 ![]() the 650 will still run xfire 5850's with room to spare tbh. Also RAID0 will outperform your raptor, but its up to you. You did say criticise. lol |
Originally Posted by Reflux ![]() It's the Megahalems that needs good airflow. The H50 will work better with better airflow than the Megahalems, at least that's what that review proves. |
Originally Posted by Reflux ![]() Already at the peak of my budget. Not adding £200-£400 more onto that. I actually can't. |
Originally Posted by arbalest ![]() ISSUE SOLVED <-- You can piece together a loop for $100 easy! There is some CHEAP UK deals as well all the time! |
