Which
  • i7
    Votes: 40 59.7%
  • 775
    Votes: 27 40.3%
1 - 17 of 17 Posts
· Premium Member
Y'know what. I would go i7 if you have the cash.
But the wise decision would be to wait a month or so till prices drop a bit and you can make a more informed decision.
Originally Posted by The Master Chief View Post
I have the money, I think I will go i7. But some of it will be a Christmas present.
Then maybe get the cpu now as the newer ones may be binned better and OC better.
See if you can get your Christmas present on boxing day as stuff will be cheaper and there should be more low voltage (the recommended 1.65v) DDR3 out by then.
· Premium Member
Lol ok. I might as well bite the bullet and get i7... Although my Coolermaster hyper HSF would be useless, unless they come out with an i7 attachment.
You might be able to mc'gyver the thermalright 1366 retention mount to work on the coolermaster HSF.
· Totally New to OCN
Good, luck, I cannot decide either =)
It is liek a dif off 1200, or 800 for an entirely new build minus Monitor, hd and such
1 - 17 of 17 Posts
