1 - 13 of 13 Posts
Xeon W3530! It'll probably get you higher OCs.
Not So Avid Enthusiast
I'd go the Xeon route. I believe they are much better binned and have higher overclocks without as much heat as the regular i7's.
Edit: If you want, you could drop to the W3520. Basically the samething but a lower stock clock.
i7 = xeon
xeons are normally binned better, but the 950s binned pretty good too.
in a single physical CPU board, the xeon will be identical to its i7 brother at the same clocks.
Originally Posted by Danounet View Post
Without talking OC. Which would be better though?
I just want to see both sides of the story
the i7 because its clocked higher. and that is the only reason. if the two chips had the same clocks they would perform exactly the same, because they are the same exact chip. (ok, the xeon has dual QPIs, but thats only used when there are multiple CPUs on the mobo)
really... im being serious, im not just saying they are similar chips, they both use the same exact die (besides the dual QPI, which is irrelevent here)
Discussion Starter #8
Thanks everyone!
As you can tell I dont know much about Intel CPUs, just learning as I go.
Xeon it is then
Now another question. Which Xeon around $300 should I get?? Again not set on OC at the moment. Maybe down the road when the PC starts to get a bit outdated.
Thanks everyone!
Xeon it is then
i just said the i7 950 is faster stock due to the higher clock, and it will be better if you oc because it has a higher multi. but you are kinda stuck to that xeon around $300 because the rest are much more expensive. if you want one with higher clocks...
Discussion Starter #11
I was taking in consideration the other comments as well. I'm not really set on anything... hence why am asking. All the info in a short time gets confusing.
if OCing isnt your thing, i would 100% def go with the i7 950
1 - 13 of 13 Posts
