1 - 20 of 44 Posts
I ORDERED ALL OF THE FOLLOWING! =D 8/3/09
This computer will be used for some hardcore pv gaming and some general internet usage. Can you guys tweak this rig a little bit. Also all I looked on for parts was Newegg.com, so if you know where some parts = to or close are could you throw a link? If possible can you guys list some parts that are a little cheaper? This is right at my budget, but I want to get it as low as possible. And if I am missing something, PLEASE tell me!
Case-
http://www.newegg.com/Product/Produc...82E16811119160
COOLER MASTER HAF 932 $150
CPU-
http://www.newegg.com/Product/Produc...82E16819115202
Intel Core i7 920 @ 2.66GHz $279
CPU Heatsink-
http://www.jab-tech.com/Prolimatech-...6-pr-4428.html
Prolimatech - Megahalems $60
Motherboard-
http://www.newegg.com/Product/Produc...82E16813186169
Foxconn Bloodrage $220
RAM-
http://www.newegg.com/Product/Produc...82E16820145224
CORSAIR DOMINATOR 6GB (3 x 2GB) $150
GPU-
http://www.newegg.com/Product/Produc...82E16814130433
EVGA GeForce GTX 260 Core 216 Superclocked Edition 896MB $160
Sound Card-
Can I just use an old one out of my PC?, then save up money to get a good one. Free
Hard Drive-
http://www.newegg.com/Product/Produc...82E16822148433
Seagate Barracuda 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" $90
Keyboard- Dell Free
Mouse- Dell Free
Monitor 19"? Free
PSU-
http://www.newegg.com/Product/Produc...82E16817139009
CORSAIR 850W ATX12V 2.2 $120
$1389
After MIR. Free shipping on most of it I think.
I need an OS =/ Can I use the vista disc for my other computer until W7 comes out?
do you live buy a www.microcenter.com ? they have cheap i7's. for 30$ i would go with a 4890 by XFX, they have a lifetime warranty and the 4890 KILLS or even a 4870 1GB which has better benches . also, why the v8? why not a TRUE/Noctua/xigmatek?
Originally Posted by phospholipid View Post
do you live buy a www.microcenter.com ? they have cheap i7's. for 30$ i would go with a 4890 by XFX, they have a lifetime warranty and the 4890 KILLS. also, why the v8? why not a TRUE/Noctua/xigmatek?
No, and I am stuck on Nvidia. And this was kind of thrown together this morning. I want a lot of feedback, I read somewhere to use a v8. So which exact heatsink would be good?
Also. not enough difference to care. Another thing, I would like to step down on most things not step up. What things can I cut cost on?
One more thing, is the tri sli motherboard overkill, since I will only be running 1 card until Christmas?
Discussion Starter · #6 ·
Originally Posted by TheMonster View Post
I need an OS =/ Can I use the vista...nough for the rig and heavy overclocking+SLI?
STG3 VET
Can I or will I have to buy Vista =/. W7 comes out in like 3 months.
Will 850W be enough for the rig and heavy overclocking+SLI?
yes, it will be plenty
Discussion Starter · #8 ·
Nevermind sticking with Corsair.
Is it possible to download Vista off the disc I have at home? Or do I need a key or something?
http://www.newegg.com/Product/Produc...82E16832116678
Vista plus free W7 coupon?
But I don't have this kind of money, I need to cut cost about 150 if I do that. I might have to cut costs anyway.
Just remembered I get a paycheck monday. So my budget is about $1700 USD.
Also quoted off another forum.
"You can lose the vista ultimate OS and DL server 08 for free for at least *cough* like 240 days. it is the same as vista 64, btu you can customize it more and it is less of a resource hog. after the 240 days you can either purchase a copy, or re-format."
Discussion Starter · #9 ·
Wow my post was doubled for some reason.
What about CD drives, im lost there, can I get some suggestions on what I will need.
the EVGA board is a little overkill if you're just gonna be doing 2 way SLI max. i mean, the evga board is for hard core OCer's with water/LN2. you can get awesome clocks from a Foxconn bloodrage/ Asus P6T Deluxe V2. you can cut 70-120$ there pretty well.
also for your OS, see if any of your friends at Universities have MSDN's [where they get site licensed products] or student discounts. :]
also, you're missing an optical drive [cd burner] LG and samsung make the best IMO, the quietest out of all the ones ive bought. ASUS's CD burners break to easy :[
Discussion Starter · #11 ·
Alright thanks, I will be doing 3 way SLI, but thats toward the end of this year. So I would still like to have that motherboard. Optical drives, thanks.
when its back in stock
http://www.newegg.com/Product/Produc...82E16827151171
Discussion Starter · #13 ·
Discussion Starter · #15 ·
K, I am lost when it comes to any optical drives. I really just want to get the basics of the computer running first, then worry about the rest. And I can probably get dvd/cd drives at a local pc store.
A 22x DVD drive shouldn't cost you above 20$. To be realistic, your DVD/CD Drive is probabl going to be used the least. unless youre heavy on media or something. The only time I ever use mines is if i need to burn something or if i need to install an OS/game
and for your OS, generally, Vista OEM editions can only be installed on 1 PC at a time. when you install it on 2 PCs, you won't be able to get updates for the OS because its sharing the key with another hardware set. but there's a way you can get away with it; I'll see if i can find a link on the interweb for you
Discussion Starter · #17 ·
Alright, I am going to drop by the local pc store, see what they have there.
Thank you so freaking much! That would save me a lot of hassle until October 22nd
you can use the Release Candidate for now, itll work until June 2010 and will start shutting down in march 2010 I believe. its free now
Discussion Starter · #20 ·
Alright thanks.
Originally Posted by Croft
This promo code will dock $10 off your i7 cpu price:
EMCLVNP27
Thanks man +1 to both.
1 - 20 of 44 Posts
