Unplug your computer and touch the case with your hand, then with your other hand touch something like a radiator, or something else that is earthed or grounded, do this for 20 seconds it will take all the static electricity out of your case,
Secondly make sure it didnt blow the tripswitch at your switchbord, if it tripped the switch you will have to flip it to the green position.
good luck mate
good luck mate
