i7 voltage question
264 5
Hey everyone,
I was wondering what people with dual high SLI cards set their IOH voltage to? I've seen online a lot do 1.3v. I know there's a sweet spot for optimal performance based on how OCed your GPUs are but what would be the minimum you recommend to avoid any stability problems?
Also, people with unlocked multipliers, if the CPU OC is only done via multiplier, the only voltage that I have to increase is the vCore right?
Thanks a lot.
1 - 6 of 6 Posts
Free bump (curious) especially about IOH volts.
AFAIK,the only thing you'd fiddle with is vCore for unlocked multipliers.
Discussion Starter · #6 ·
That's the weird part, VTT is the IMC voltage and of course deals with the bclk and some people claim that it still helped stabilizing their multi OC.
1 - 6 of 6 Posts
