To support the micro build I obviously need a micro case. I wanted to do a small form factor since my PC is in an armoire right next to where I work. I got tired of having a loud, towering, glowing, dust magnet taking up a lot of space with all the distracting bling. This is also why I wanted quiet.
The PC DesignLabs Qmicra was selected for its airflow, appearance and modding capability. I've had my eye on the Qmicra since the first version.
I chose the black powder coat with a blue Bulgin vandal switch, blue HDD light and sound deadening already installed. I probably didn't need the sound dampening since the case is so open and I'm not sure how much effect it will have?
One cool feature of this case is it allows you to mount the PSU in either orientation. This may come in handy if I add a blow hole later.
This case can accommodate up to seven 120mm fans, four HDDs and three 5.25 bays, just not all at once. Actually, with its design the combinations are endless. There is also a fair amount of space for water cooling for a small form factor case.
Total damage including shipping = $274.85
