Originally Posted by Jasonn20;13083364
Where did you get I was complaining and I need 5ghz..? I was wanting to know how this chip stacks up against a few others.
Ok Jason,
Calm down, go into your BIOS, set it back to x34, boot back into BIOS,then tell me the default VID in white (shown next to the manual cpu voltage selection to the right of it).
I'm guessing you have a high VID chip (1.245v or higher) but i want to see...
Also when you set it to x50, 5 ghz, and PLL overvoltage enabled, and you select your 1.5v in the BIOS, is the VID showing as 1.390 or 1.395v ?
