Hi all!
Long time reader, occasional poster.
Recently picked up an 920 d0 (specs in the sig) to replace my "aging" Q6600.
The first thing I... does anyone wanna take a guess?
... Ok, enough with the bad jokes... I'll skip to the good/bad part.
Overclocked it to 3.6Ghz @ 1.264 vCore without any issues... 3.7 required a bump to 1.298, and 3.8 @ 1.312. All have passed Prime95 and have been stable. So I tried my luck and went for 3.9 Ghz. My first pass of P95 crashed 30 minutes in. I didn't want to increase my vCore as it it already @ 1.337 in the bios (1.312 in Windows under load), so I lowered my UCLCK Multi to 17x instead of 18x, and currently it has been P95 stable for 50 mins. I feel that I picked up a bad batch/chip because most d0 owners can get 4Ghz with 1.20-1.25 vCore, not to mention that my temps are 67-73 depending on the core. Thoughts?
The following are my settings in bios... maybe some of the veterans OCers can help
Cheers!!
CPU ratio = 20
BCLK frequency = 195
PCIE frequency = 100
DRAM Multi = 6x
DRAM frequency = 1171MHz
DRAM timings = 7-7-7-20
UCLK Multi = 17x
UCLK frequency = 3315MHz
QPI Multi = 36x
QPI link data rate = 7020MT/s
CPU voltage = 1.33750V (Bios)
CPU PLL voltage = 1.88V
QPI/DRAM core voltage = 1.35V (I think, I'll have to double check)
IOH voltage = 1.2V
ICH voltage = 1.2V
DRAM bus voltage = 1.64V
Load line calibration = enabled
Intel HT = Disabled
Intel Speedstep = Disabled
Execute disable bit = enabled
Cheers!!
CPU ratio = 20
DRAM Multi = 6x
UCLK Multi = 17x
QPI Multi = 36x
IOH voltage = 1.2V
ICH voltage = 1.2V
Intel HT = Disabled
