I think a higher percentage of over clockers are limited to ambient temp cooling in the form of water cooling or air heat sinks.
This club is for those that don't have access to sub ambient temp cooling like liquid nitrogen or chilled water ect....
Post your 5GHZ+ benchmark accomplishments, stability temp testing results with IVY BRIDGE CPUS.
To get into this club all you have to do is post a CPU-Z screen shot and valid URL of your IVY BRIDGE CPU at 5GHZ+ AND a screen shot of a 10 run pass at standard setting run of Intel Burn Test with HYPER THREADING OFF or ON but make sure you state whether or not your HT is on or off. Also please post a REAL TEMP screen shot of your Temps of your IBT test.
Any voltage tweaks tricks that have helped your reach 5ghz? Is so please share.
