Hey there!
So I just finished a 1hour stress test in Prime95 (Read that this is fine for normal use such as gaming, which is what I will be using it for).
There are a few things I would like to ask.
First off, the test was fine for 1 hour but at 4 minutes left I got a message: Windows Network Service (iirc) has stopped working.
The test was still fine, I let it run for the last 4 minutes and everything seems fine.
Does this mean it's not really stable?
Temps maxed at 80C on two cores. The other two maxed on 77 and 76.
I achieved 4.5GHz at 1.28Vcore, I had 4.4GHz at 1.22GHz which was stable for a 5min run in Prime95. I tried everywhere from 1.24-1.28 at 4.5GHz and only 1.28GHz would run for even minutes. 1.24 and 1.25, Prime95 stopped responding. 1.26 and 1.27, BSOD for more Vcore.
Should I rather step back to 4.4GHz at 1.22 or maybe even 1.21Vcore or is there anything I can do to try and get lower Vcore on this OC?
For RAM settings I had some issues at first so I set it to XMP and it worked fine. Timings are 8-8-8-24 2N, V = 1.65. Anything else that concerns RAM is auto.
For other settings I used some that were suggested (by david82282) in another thread:
BCLK = 100
CPU_LLC = UltraHigh (75%) -- this should keep Vload almost the same as the Vcpu in BIOS -- I get 0.01 overshoot.
CPU_Power_Phase = Optimized
CPU_Voltage = Manual Mode
V_PLL = 1.60 (this is said to drop temps a bit, or allow a lower Vcpu)
V_DRAM = 1.53 (with 16GB, it probably helps to have some reserve)
Spread_Spectrum = Disabled (though probably doesn't matter for BCLK=100)
CPU_Current_Cap = 140% (it's red, but seems to be necessary for high OC).
Everything except for the V_DRAM I have the same as his.
Anything else is auto.
Also a few times I got some BSOD's that in another thread were said to be from too low QPI/VTT but in the BIOS of my Asus P8Z77-V Pro there is no setting to change that, I could definitely not find it anyways. I just changed the Vcore and it went away.
So yeah, basically I am wondering if I can stick with this OC for 'normal use' (Gaming, watching movies and such), if there is anything I can try to get lower Vcore and if I did anything completely wrong. Or if I should just go down to 4.4GHz and conclude that my chip is not amazing.
Thanks!
Edit: Also in CPU-Z it's at 1.288 at idle and 1.296 iirc at 100%.
More edit: I was also looking for iGPU settings since the 3770k people said disabling it would lower temps, but for my 3570k I have no iGPU settings. Is this normal? I can't say I am very familiar with the whole iGPU thing.
BCLK = 100
Thanks!
