Hi guy i am going to try ic diamond i read on there site that it says to use a 5.5
Millimeter bead in the center of the cpu. and i don,t got a Millimeter ruler
so what is 5.5 Millimeter in inches .
is it a little of 1/4 are under.
and it say to let the ic diamond set for 10 min be for alpying the cooler.
then let it cure for 1 hour. that mean let it sit for one hour befor i turn the pc on right,.
