IC7-G Max2
630 2
I have a Pentium 4 2.4 GHZ (533 Mhz bus speed), and it is a Northwood Processeser. The Specs for the Abit Ic7 say "Socket 478 for Intel Pentium 4 Processor (HT Ready) FSB: 800/533MHz only(400MHz FSB not supported)" Does this mean that my processer will not be supported, or that it will run at its normal 533Mz?
1 - 3 of 3 Posts
Your processor is supported, don't worry
I don't understand. You said that your cpu is 533 fsb, then you said that the board supports 533 fsb, sounds like you answered you own question
1 - 3 of 3 Posts
