Originally Posted by SpencerM Anyone know what the main performace boosts are between the IC7 and the IC7-G MaxII? They are both from the 875 chipset, but I dont know what makes the MaxII better. |
Originally Posted by SpencerM Would you reccomend it for the price difference of 50$? |
Originally Posted by NoAffinity - Supports Performance Acceleration Technology (PAT) function - Supports Plug-and-Play (PNP) - Supports Advanced Configuration Power Interface (ACPI) - Supports Desktop Management Interface (DMI) These things are chipset- and/or BIOS-specific, not mobo-specific. Both boards will support these features. ![]() |
Originally Posted by xms Which means that there is no speed difference between the IC7 and IC7-MAX boards? |
Originally Posted by mfillpot According to my understand of ABIT the IC7 line is all basically the same perfromance wize, the only differences are possible connections. NoAffinity can you back be up on this? |
Originally Posted by xms If that is indeed the case, then my post here about the Asus being faster could well be true: http://www.overclock.net/showthread.php?t=6124 |
