Are you going to have it sandblasted or do it yourself? I personally would just sand and paint it. Sandblasting if done wrong can really warp the panels from the heat it generates. Now if they or you use walnut shells or baking soda you should have no problems. |
Is there a reason you think it needs blasted? If it still has stock factory paint I would use that as a base. Blasting will leave a pretty rough surface that will need quite a bit of primer to smooth it out and multiple sanding passes. Even with it backed up it could very well still warp, it's not the pressure but the heat that will warps the panels. What kind of blaster do you own and how big is your compressor? Hope that helps. Not trying to talk you out of it just hate to see you do so much unneeded work. But.....blasting is fun! Very manly! |
