1 - 18 of 18 Posts
are IDE SSD's old? are they any good? the 2.5" ones
and what about CF to ide adapters?? are they better than normal IDE
IDE SSD are definitely old... I wouldn't touch one being 1st gen or even pre-1st gen.
It shouldn't be because ultimately you'd be using the IDE interface, so it should be on the same bus.
Originally Posted by anon-nick
would a compact flash to IDE converter be faster than an IDE drive in my titanium powerbook?
No, Compact Flash is not suited for an OS drive. They don't have wear algorithms and are designed for high-bandwidth or high random write.
I've merged the threads.
CF performance greatly vary.... However, you're usually looking at something like 30-50MB/s and 1-15ms.
Also, there's no wear algorithm so it will wear out fast.
Originally Posted by anon-nick View Post
so for longevity, its not any better than an old IDE?
Compact Flash will have lower sequential performance, stutter, wear out faster, be more expensive, and offer less space than an IDE HDD.
well if you can you might be able to get a small SATA one and jam it in with an IDE/SATA Adaptor... but probably not..
Like for example an X18-M drive (1.8 inch, so you might have enough room to jam in a SATA/IDE adaptor... but really it's going to be hacky..
So, combine this
With one of these
Probably still won't fit the bay tho... just saying it is "possible" but is it worth the trouble?
1 - 18 of 18 Posts
