Ideas for use of an Old GPU fan
4895 Views 30 Replies 18 Participants Last post by  T3h_Ch33z_Muncha
hey all,
I pulled apart the old 7600GT and took its fan off.
any ideas what i can / could use it for ?
1 - 20 of 31 Posts
Use it to suck hot air from the top of your 9800GTX+ and push it out of the case.
how ?
what would i plug a 2pin connector to ? and are suggesting i place it on top on the exposed circut ?
Attach it to the end of a woodwind for automated grooving.
Considering that its probably UBER loud, you should probably annoy people with it.
see if its mount holes match up with your NB?
Originally Posted by cs_maan View Post
considering that its probably uber loud, you should probably annoy people with it.
+1 :d
northbridge is under a Noctra U6B already,
a slot cooler? you can use it to help cool your graphics card by evacuating the hot air trapped under it
what would i plug the lil 2 pin conector to though ?
you can mod a molex to take it i bet you just have to find out what are the 12 volt leads
I have one laying around too, although bigger.
Only reasonable place I would put it is on top of a hard drive. I let go of the idea because an 80mm fan would do a better job and look cleaner.
What I would do is remove all the plastic until you have just the flat heatsink left. Then with that there's many uses.
I'd like to add, I just looked at my old 7900GT stock fan, wow its tiny compared to yours, and its a 7600 fan too!
USB Laptop cooler! I made one out of my x850xt fan
+1 to that!
Seriously either that or take off the heatsink and use the plastic body with the fan as a turbine.
surly it only has limited cooling capacity right
Wait, that fan is pulling air out right?
Yeah looks like it is.
Edit: pic added of how I think the air flows in the fan housing.
actually it looks like its blowing into the laptop, which would be backwards.
make a beverage cooler!
1 - 20 of 31 Posts
