Ideas on new WC Setup
666 13
I'm about to invest in a decent WC setup, and I was hoping to get some feedback on these items I'm about to put together. The list is as follows:
DD 1/2'' ID 775 Waterblock
http://www.frozencpu.com/ex-blc-231.html
DD Chipset Waterblock (1/2'' ID)
http://www.frozencpu.com/ex-blc-187.html
DD NV-78 Waterblock (1/2'' ID)
http://www.frozencpu.com/ex-blc-224.html
Hydor SELTZ II Pump (740 GPH... 1/2'' ID) -- overkill?
http://www.frozencpu.com/ex-pmp-39.html
DD Black Ice Xtreme III Radiator (1/2'' ID) -- Look at RIG 1 in my sig, it'll go right behind the 3 virtical 120mm fans.
http://www.frozencpu.com/ex-rad-45.html
Blue UV 5.25'' Res. (1/2'' ID)
http://www.frozencpu.com/ex-res-36.html
Some LCD thing to take up the extra 5.25'' space
http://www.frozencpu.com/ex-pmp-35.html
Lemmy know if you'd change anything and/or what I might not need. I'll get tubing and that non-conductive coolant. Thoughts?
1 - 14 of 14 Posts
Well this is what everyone's going to tell you as I had the same questions and I'm in the same process as you
1. The chipset block is a waste of money
2. Look at the Swiftech Apogee as its the best block out for multiblock setups
3. The danger den d5 pump is the best.
Hmm... I've heard about the Apogee, but I wanna be able to see the coolant for some odd reason. I'll consider it... thanks for the advice.
indeed, most of us are gonna say similar things...
dont get the chipset block
get a D5, danger den or swiftech branded
ditch the black ice xtreme and buy a heatercore
I guess if you really want the bix for mounting convenience, then go ahead... but spending $ 125 on that bix when you can buy a heatercore that will outperform it for ~ $ 20 doesnt make sense to me... Id sacrifice a little aesthetics and ease of mounting to save ~ $ 100
also, what color did you want your coolant?... cause if youre only getting the tdx for the acrylic top, you can browse http://www.voyeurmods.com/index.php?...id=2&subid=209 and find a color that you like or that fits your theme
Originally Posted by pauldovi
They made the Apogee with a clear top... not sure where I saw it though. Just search google for it.
my link, for one...
Are you talking about that PrimoChill ICE stuff? How much do you think you would need for a 1/2" ID T-line system with a D5, TDX, Maze4 and BIP in the loop? If we just used dyes, what could we use as an anti-algea/corrosion liquid, as Anti-freeze will probably goof up the dye's effect (as it makes that gross yellow color).
OH yeah, here's the acryllic top for the Apogee. *shrug* I think the TDX looks better though....
http://www.voyeurmods.com/index.php?...=2&prevstart=0
Discussion Starter · #9 ·
I've seen the dual heatercore, but will it really out-perform the black ice xtreme III? I'd have to get radiator shrouds to mount the thing (around $10), but I think it'll be an eyesore. That's about the only thing stopping me from getting it.
Thanks for the acrylic links for the apogee, those look really neat, and you've changed my mind on that item.
Can someone add a link to the DD-5 pump? Also, a link to the proper sized tubing that I'll need for the 1/2'' ID, which I assume is 5/8'' OD tubing.
I'm kinda sticking with the blue theme with yellow/green UV coolant.
I'm looking for soemthing useful and aesthetic for the remaining 5.25'' slot if anyone has any ideas...
d5 pump: http://jab-tech.com/Swiftech-MCP655-...p-pr-2982.html or http://www.dangerdenstore.com/produc...&cat=23&page=1 ... both are the same thing
dual heatercores were built to cool liquid while inside an engine, itll handle computer cooling easily...
... the shrouds arent necessary... and like I said, aesthetics are important for some but I prefer performance over all else
you could do all sorts of stuff to hide the heatercore, such as build a wooden box around it to act as a shroud and to help it look nicer... I dont want all my watercooling parts close to the comp anyway so Id put everything into its own self contained box, tub, etc. and only have the tubing and blocks in the case
as for tubing, check out http://www.mcmaster.com and pick some nice tubing thats 1/2" ID and 5/8" OD
I dont like lots of stuff in my 5.25" bays, so thats up to you...
Discussion Starter · #11 ·
I found an article that tested a lot of radiators, as well as the dual heatercore and compared them.
http://www.phoronix.com/scan.php?pag...item=328&num=2
From these results, I'd be a willing to pay for the extra surface area, aesthetics, and easy mountability of the BIX III. So, I guess I'm being kinda stubborn on that matter.
I saw that there are some Swiftech Storm CPU waterblocks for $80.00 on that vouyer website... are those still in production or has the Apogee taken over as the dominant performer?
Thanks for the links, Nut.
youre not being stubborn, you just want what you want... Im sure youll be happy with it...
youll see everyone going around bragging that the g4 storm is better, especially since its based off of a cathar design, but if you check the reviews, youll see that the apogee and storm perform very close, if not identical
http://www.systemcooling.com/swiftech_apogee-01.html
http://www.ocia.net/reviews/apogee/page1.shtml
so to me, considering the performance of both, the storm isnt worth the extra $... especially when you can get an apogee from www.jab-tech.com for $ 40 if you enter "Cryo-laboratory" in the coupon code box in your cart
I woud go with the DD5 pump.
TDX block is good as is the RBX, but if you plan on bringing water temps below ambient, th Lucite top bock has a propensty to crack.
I would also reccommend against the BIX III. For the rpice of that, you could buy and modify a '77 heatercore, make shrouds out of tupperware, and buy 4 100+ CFM fans.
Unles you are going below ambient, the chipset block is superfluous and restricts flow.
SNERP!!!
HERE is a pic of my heatercore all painted up. It dosn't look bad at all. I've put another layer of paint on it so you can't see the edges of the tape so it looks very clean and smooth.
1 - 14 of 14 Posts
