1 - 4 of 4 Posts
Man with Fans
I plan to buy a used Seasonic M12 II 430.
The person is selling it for 55SGD (roughly 42USD).
Is this a normal price for a used M12 II 430?
Also, to ensure that he isn't passing off an abused PSU, how do I go about testing it?
I plan to do the following:
Torchlight - physically check the internals for any sign of damage.
Check warranty seal.
What about loading?
None of us has an ATE, and I know OCCT isn't a reliable tool.
Am I safe to assume that by loading up the OCCT PSU stress test and manually probing the +12V and +5V lines with a DMM, that this is a trustable way of checking if the voltages are stable and in spec?
Thanks.
Super Moderator
The above methods, but also probe each individual rail (3.3v, 5v, 12v, etc...). Make sure you probe them all
. Although I'm sure just the 5v and 12v would likely be sufficient.
Other than that, I honestly don't know. $42 USD is a decent price for a PSU. It sounds a little expensive, but that could be because of exchange rates. For example, there's a Tuniq 1000w unit on newegg right now for $60 USD after rebates. But that's actually a rare price.
Man with Fans
Kewl.
I'll grab a small multimeter to probe the 3.3's.
Argh. OCD is consuming me now.
How can my old-ass, abused, dusty workhorse bedroom PC have a modular PSU while my sig rig has to contend with that octopus in it.
I have no complaints regarding the performance of my PC P&C (Seasonic S12D), but it's probably the worst purchase I've ever made.
Cables overkill FTL.
Man with Fans
Discussion Starter #4
So, is that all I should do to ensure a functioning PSU?
I'll be picking it up tomorrow so any last minute advice is helpful.
1 - 4 of 4 Posts
