1 - 11 of 11 Posts
I upgraded at work from IE6 to IE7<br />
<br />
I do a lot of switch from 1 window to another window using ALT-TAB<br />
<br />
but I want to use a similar shortcut in IE7<br />
<br />
In FIREFOX TAB-CTRL works to switch from last tab to the other one.<br />
<br />
but not in IE7. the shortcut MS says is CTRL - SHIFT - TAB.. and that is VERY annoying...<br />
<br />
I want to change that shortcut...<br />
<br />
PS. i cant use firefox because our intranet only works with IE
Maybe you could move the mouse cursor up to the top of the screen and depress the mouse button while over the tab of choice? <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
Some call me... Bifford
How is ctrl-shift-tab more difficult than ctrl-tab. The buttons are right next to each other, just use the same finger to depress both at the same time.<br />
<br />
EDIT: just ctrl-tab works for me (in ie7) anyway. I am not sure I understand the problem.
I might have tacos tonite
control tab works fine for me also, you sure it doesn't work for you?
Discussion Starter #6
ALT TAB will scroll from program to program in the taskbar<br />
but it won't cycle through the actual tabs.<br />
<br />
<br />
CTRL-SHIFT-TAB is not very easy to do
<tr>
<div>
Originally Posted by <strong>xsabrewulf</strong>
<a href="showthread.php?s=5f012238fa36186cbb85825ea8d4fba8&p=1389425#post1389425" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">ALT TAB will scroll from program to program in the taskbar<br />
<br />
<br />
CTRL-SHIFT-TAB is not very easy to do</div>
</td>
</tr>
</table>
</div>Try just CTRL+Tab. I'm doing it right now and it works fine.
Old Timer
If you hit CTRL-TAB in IE7 it will switch tabs...
CTRL-TAB goes from Left to Right<br><br>
CTRL-Shift-TAB goes from Right to Left<br><br>
It does for me.
Goodbye
Are you actually having an argument over buttons?<br><br>
xsabrewulf was there actually a question in this thread or just a blank statement?
1 - 11 of 11 Posts
