Just remove the CMOS battery out of ti and leave it out for 10 mins im not sure how much but an hour should be enough.
Also hit the on switch when the plug off to use up all the stored power.
Now turn it on you jsut need to input date and some settings in BIOS.
Well, actually, I don't know how much it differs depending on what motherboard you're running, but I only need to keep my CMOS battery out for about 15 seconds and it resets my BIOS.
yeah i used clock gen... didnt have a good experiance i set the settings from 2.8ghz to 2.9... and beep boom the computer went down........... yeah im never using a software overclock .... mehhhh need a modded bios than ill feel a bit safer with overclocking :\\
Okay guys. I overclocked too high on my old cpu (pentium 3 800MHz, asus cuv4x) and I took out the battery and left it out for an hour. Put it back in and my bios is not reset still...
First unplug the power cord or flick the switch on the back of the power supply if you have one. Next hit your power button to remove all the stored up energy. Since you don't know about your Cmos jumper, just take out the battery and leave it out for 1-10 minutes. Place the battery back in and plug the computer back in or switch the psu again and turn it back on.
Just use the cmos reset jumper, after looking at the manual for your board it is confirmed. The jumper is right next to the battery as usual... diagram here:
EDIT: to use this jumper simply short the pins as it says, easily done with a spare hard drive jumper or if nothing else a small piece of metal (flat head screwdriver?) turn on the computer (while pins are shorted) and then unshort the pins, once the pins are unshorted the computer will turn on. then go back into bios and try again =)
1 - 13 of 13 Posts
