I have a pair of Refrence design 6970s so the watercoolers can be found for cheep. actually there is one on ocn marketplace for $45 dollars, so I would need about $90 dollars for the heat-killer blocks plus a radiator and lines.rez, fittings and so forth.......Iam wondering if i was to run 3 6970s watercool them and use em for gaming? Or just save-up for a pair or tri 7970s and waercool them? What temps can u get under load if you are using water??? Right now during gaming iam at 60c under full load, also keep in mind it will take me ALOT longer to get 3 7970s then just add 1 more 6970,tri 6970s would be good for eyefinity beacuse I mainly play flight-sims. Iam also curious how long these 2 gb would last me? Maybe another year if iam lucky? Ive just upgraded my cpu to the 8350 and also the mother board Formula- z , I ran eyefinity just fine on my fx 6100/ m5a97 mobo, how does this set-up look to you??? Thank you and sorry for all the questions:thumb:
