1 - 8 of 8 Posts
I was looking at the Biostar TP67XE and I see it has one connection for the rear fan, one for the front and one for the CPU HSF. Well what if I wanted to add another fan on the HSF for p/p? This one to be exact
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103060
I see it has a 3/4 pin connector which wouldn't do me good since there's no more room on the mobo. I see the fan comes with a power cable that has two 4 molex pin ends on it, but I'm confused. One end of that connects the the psu, but where does the other 4 pin end go that'd make it associate with the fan? I don't see any way to connect the 4 pin molex to the fan in question.
semi-legit
^ Yea I either run fans off the PSU directly or through a controller. I hate having wires connected on the mobo, ruins my cable managment ocd
Reactions: venomblade
Originally Posted by Jonsu View Post
Ahah... Didn't see it at first, so I jump right to conclusions. But yeah, use this adapter to be able to use the fan
227
Aha! That solves my question, didn't see that part either, +rep to all!
1 - 8 of 8 Posts
