I've just invested in a new fan, a scythe kaze juni 1900 rpm, and spent the last 4 hours rearranging my fans to get the best temps (and having the fun of figuring out which screws go in which fans--are there any generic plastic plugs or something I can use to save me this headache?), and after all my efforts the temperatures are still a joke.
I am running my sig rig at 3.4 ghz and 1.1 vcore, which I don't think is high at all. Cores are average 45 degrees at idle, yet spike up above EIGTHY under stress.
The fan configuration is:
v v
<- <-M<-
EDIT: the formatting got rid of the spaces in this diagram... the top two arrows are positioned above the "M".
The M is the megahalems. I moved the front fan that came supplied with my case to being an exhaust fan on the case, and the rear exhaust fan to being an exhaust fan on the heatsink, and stuck the two akasa Akasa AK-191-BL's that were formally heatsink fans to the top of the case as intake fans.
I applied diamond paste to the cpu by manually spreading it evenly with the fingertip of a clean disposal glove until it was hair-thin and I could barely see the writing on the surface of the cpu. I finger-tightened the megahalems until I couldn't tighten it any further, and I have pretty strong fingers.
Does anyone know if these temps look abnormally hot or are to be expected given that most of these fans are rather weak (the new scythe, the pushing fan on the heatsink, claims to have 110.3 cfm--I'm not sure how strong the stock case fans are that are now both acting as exhaust fans--I have all fans wired directly to the PSU).
v v
<- <-M<-
