maybe custom build a laptop cooler with 80mm fans under the intake holes of the lapp (blowing up of course)...thats the best you can do with air cooling...
orrr...take one of those AC units and rig it to blow through a pipe right up your laptop's intakes
Enterprise yes i realize that i typed it and must of not been paying attension(duh) but ill rig something upp soon What are some of the things i should get
Well to cool it better, you can be daring and pull the thing apart, remove the stock cooler, lapp it, apply AS5 and replace the small fan with a higher flow one. Then get a nice laptop chiller. That should drop temps a good bit. Though even after that i still wouldnt reccomend overclocking a laptop, unless you custom water cool the thing, which would be awesome!
Overclock.net
