1 - 8 of 8 Posts
Questionnaire galore!
semi-legit
Switching back to XP because of a driver issue with an OLD card is a terrible reason to do so.
I'd recommend either a) continue to troubleshoot said issue or b) get another (newer) card on the cheap and move on
Originally Posted by candy_van View Post
Switching back to XP because of a driver issue with an OLD card is a terrible reason to do so. I'd recommend either a) continuing to figure out said issue or b) get another (newer) card on the cheap and move on
Don't have the cash and WHY DID A FX5500 WORK ON W7!!!
W7 Just hates me i know it!
semi-legit
No idea, but seriously though don't switch back just for that. At the very least just dual-boot 7 and XP until you figure it out
You can get a 3450 for $20....probably cheaper cards too.
Discussion Starter · #6 ·
No idea, but seriously though don't switch back just for that. At the very least just dual-boot 7 and XP until you figure it out / can get another card.
Well insstaling W7 is easy so i think i'm just going to format the thing.
Until i find a solution or get a new video card but while i'm with XP i'm going to Overclock my PC to Hell
I'm in the Philippines every thing here is not cheap even gas.
Discussion Starter · #8 ·
I will just dual boot when XP is insstaled
1 - 8 of 8 Posts
