1 - 6 of 6 Posts
Ok, so I've tried to burn the window 7 beta on a dvd, but I really don't know what to do after that. My laptop (which I'm going to install it on). It doesn't install on the hdd though. I'll try to get it installed, but it really doesn't let me...
If anyone could let me know how to get it installed, I'd greatly appreciate that.
Thanks
Discussion Starter · #2 ·
Your computer can't run this version of the OS.
That is the message I get on xp.
Are you trying to install a 64 bit OS on a 32 bit machine?
Edit: Also Win XP shouldn't be telling you anything if you're trying to do a fresh install. You shouldn't even let XP load. The DVD you made should have been made bootable from an iso. Then in your bios change your boot priority to boot from cd. Then pop the disc in, and restart the laptop. Then it should load the installer from the disc.
yes... I really should have checked that (I don't have 64 on laptop)
u are trying to upgrade the xp to windows 7? u must have a 64 bit XP..
try burning the ISO...
boot your PC and check (CD/dvd) priorty is the 1st
and then...it will tell you to press anykey to run the cd..
i hope i could help ...
sorry for my bad englsih
1 - 6 of 6 Posts
