My initial plan on my wife's new build was not to raid. She's got an SSD, and two 1TB WD Blacks. I was going to give her two different hard drives to play with and the speed of the SSD for programs.
Now when I went in to initialize the drives through windows, I noticed the create mirrored volume and said hmm...I know this is a "fake" raid, but for all purposes she would use this for, I thought, this could be a benefit. What I did was cut a 500GB partition on both 1TB drives, created a mirrored volume between HDD 1 and 2, and left the other two alone, so now she has two 500GB drives to play with, and a place to put family and client's photos to keep them safe in case of a drive failure.
That was my thought anyway. Now I read all about WD and their crappy enterprise marketing BS, and how these don't support RAID, that they drop out of the array, that RAID 1 "is not a backup solution" and I really don't understand why. If I were to take a folder of pictures from my daughter's birthday party and copy them onto a separate drive, I would consider that a backup. Is this mirrored volume not just making this job a little easier for the wife? (Instead of organizing copy/pastes from one drive to another she can just know that anything in this drive letter is safer?)
Since I'm not doing this at a hardware level, since this isn't using the whole drive, and since this isn't containing anything to do with the OS or heavily used files, I'm wondering if this RAID issue with blacks even pertains to me. We're not talking about running an OS in a RAID0 off 4 of these things, just talking about a little partition here for a safe zone...So my real question is this: what exactly is the risk here? Is the risk that the drive will drop out of the array and I will have to enable it again and be fine? Or am I going to lose the data when that happens? Will the drive letter simply go away, or will it split back into two different drive letters until I re-marry them again? Is RAID1 the best option here, I like it but it seems more trouble than it's really worth if it's going to cause problems and not even save data.
I have a hard time understanding why RAID1 is regarded as a terrible option for backing up data against a hard drive failure. If it doesn't do this efficiently, then why would anyone want to run it at all?
