I'm Using Avast Home and Scan archive files is Disabled???
2247 Views 4 Replies 2 Participants Last post by  N2Gaming
Hi,
I'm using avast and every time I run a complete scan the scan window shows Scan archive files Disabled. Is there a way to enable it to scan archive files or is it not avaiable on home and or is it not even necessary???
Thank you
N2G
1 - 5 of 5 Posts
I like to change my skin to the KDE one. At the bottom, there is a green square with a floppy disk. If you click that, a slider appears in the top left, drag it to the right to scan archived files.
Thank you IEATFISH, can you please tell me how to change the Avast skin?
Open the program and click the little arrow button in the top left. Then click Select skin.
You may also want to disable the sounds in the options as they can be rather annoying.
Thank you,
N2G
1 - 5 of 5 Posts
