1 - 11 of 11 Posts
My current loop is this:
RES: XSPC 5.25
PUMP: Laing DDC Pro Pump with XSPC V3 Acrylic Top
RAD: Thermochill PA120.3 with shroud & X3 Xiggy fans (61CFM) PUSH CONFIG
CPU BLOCK: Apogee XT
I am trying to improve my temps by a few degrees.
What fans would do a better job but I would like to try and keep the noise down.
Also I would like to install a water temp probe so I can monitor the temp entering the radiator and exiting the radiator.
Originally Posted by frankenstein406
Yup thats what I meant. Just go with some higher cfm fans depending what your rad likes can you do push pull?
From what I have read the thermochill can use up to 130CFM fans.
Cant really do push/pull so I think push is better.
Just want it to be silent really or as silent as can be.
Also on a side note is the DDC Ultra 18w pump better than my current pump?
Discussion Starter · #11 ·
just ordered X3 Scythe Kaze Jyuni Slip Stream 1900rpm fans to b mounted on the radiator.
Also going to mod my pump to the 18W version.
Could you please have a look at my crude drawing of my setup and advise me on fan setup and if the OEM fans could be replaced with better options.
1 - 11 of 11 Posts
