1 - 10 of 10 Posts
I just bought it chea boi!
Ok so I bought 1 hour ago.......... they said they were gonna send it in the email I kinda want to start downloading it were is it at?
Discussion Starter #8
All the stuff I have bought from them shows up in the "My Games" tab right after unless it is a pre-order.
You can try clicking on "View" and making sure you don't have "Hide non-installed applications" checked. Other than that I don't know.
I bought the game first then Downloaded the Impulse program.
I went to "My Software" tab I don't have a "My games" tab
The only thing in there is Mycolors
Discussion Starter #10
Hmmm. I would make sure you are logged in using the same email that you used to buy the game (using the blue menu button). If that doesn't work you might need to contact customer support.
It seems a few guys in the forums are having the same problem. Maybe they are having server issues?
Edit - Also, if you used paypal the email address will need to be the same as well.
1 - 10 of 10 Posts
