Sooo ok?yep u have micron![]()
corsair used to be the best, but I have been out of the hardware game for a while.yep u have micron![]()
Corsair doesn't manufacture memory they bin chips from manufacturers like micron, samsung, hynix etc and sell them as kits.Sooo ok?
Thoughts on this one? KF556C40BBK2-64Corsair doesn't manufacture memory they bin chips from manufacturers like micron, samsung, hynix etc and sell them as kits.
Unfortunately, micron is the worst for DDR5, it's first gen DDR5 so to be expected.
Not really, I've always found them the worst for ram.Sooo ok?
been on the phone with tech support with asus, and theA channel on the motherboard is having issues and now it won’t post to bios with anything in A channel. B channel with both DIMMS working independently and together in B channel alone without issue.2x32gb might not run fast even though it says qvl.... do you need 64? 2x16 not enough? be able to run much faster speeds 2x16.... i run the corsair veng 2x16 at 6200 on a z690prime-a and been working great for months. likely do 6400. havent tried... need more gpu power first
That sucks. New board time.been on the phone with tech support with asus, and theA channel on the motherboard is having issues and now it won’t post to bios with anything in A channel. B channel with both DIMMS working independently and together in B channel alone without issue.
What is worse is that Asus is out of stock: and they are waiting for more new stock before I can get my RMAThat sucks. New board time.
Wow dam poor on asus. Either they didn’t keep hardly any for rma or they have a lot of rma going on ha. Buy a different board and sell the prime once it gets there. Get a 2 dimm board unless budget is holding you back. Much better ram stability I think.What is worse is that Asus is out of stock: and they are waiting for more new stock before I can get my RMA![]()
I traded out the micron kit for Kingston fury; they said they were m-die on the sheet but they are actually sk Hynix,
my mobo is the prime seriesI can't use those yet. I do have the latest already installed though.
SK Hynix is either M die or A die.I traded out the micron kit for Kingston fury; they said they were m-die on the sheet but they are actually sk Hynix,
ThanksSK Hynix is either M die or A die.
