Originally Posted by can0lard
I have 5 80mm's in the case that drone on fairly loud so performance is more of an issue. Nothing too unreasonable though. I have a pair of old vantec tornadoes (55.2 dB!) that I don't use b/c of the noise.
Well, like the other guy said the gentle typhoon ap-15 1850rpm model is a great heatsink fan. However, if you can stand more than 30dba, the panaflo 38mm fans are great for heatsinks as well. I would say those two are the best heatsinks fans. Or, if you can get your hands on a san ace h1011 or h101, those are really good too and outperform both, but are loud and hard to find. If you need some links, let me know.
