1 - 5 of 5 Posts
Bought some new 120mm and they didn't come with screws. I had four laying around and noticed I needed this rubber piece to go into the mounting hole in order for the screw to stay and help with vibration.
What are these rubber pieces called? The ones on my case (only had four) had one large round and one small roun side and slipped into the screw hole snug. I've put all I could think of in Google and Amazon to no avail.
Thanks
These.
Bad pic but it's all I could do. It is just circular and fits in the mounting hole. That's a side shot.
Discussion Starter #5
That would be them, thanks! Didn't know what they were called but I was putting in everything I could and getting nothing lol - thanks again!
1 - 5 of 5 Posts
