1 - 20 of 58 Posts
I'm not a PSU expert - in fact, far from it - but I have trusted Corsair's PSUs for benching and personal rigs for a while. I have 3 x HX1000 kicking around here, and love them, and even have the HX850 you linked to, though I haven't had enough usage with that particular model to out-right recommend it. The HX1000 I can stand by, though.
Well my fear is, I'm getting a really really good computer. And dont want drive's and other stuff to fry!
Newegg PSU reviews mean nothing. The HX850 is very good.
And FYI, DOA's and faults can happen with any company, be it Diablotek or Seasonic.
Reactions: M3thodAngel
· Premium Member
GameBoy is spot on, the HX850 is a darn fine PSU, and Corsair's support is second to none. And I've never heard of an HX series killing a machine, without help from the user.
· Bowser Has Ryzen!!
There was only about 5 reviews out of what over 300 that actually had anything bad to say about this PSU. You have to skip past the DOA ones as these idiots give 1 egg for a doa product when they cant even review it. Even then there were only about 9 bad reviews out of 300, so thats about as good as it gets for any product on New Egg, except for maybe CPU's where they almost always get 4 and 5 eggs.
· Premium Member
I'd say go for the AX850 if you can afford it. If you use your rig a lot at higher power use (IE gaming etc) then you'll make the extra cost back inside 18 months on your power bills. The AX is under $20 more than the HX, the quality is brilliant. Well worth it.
You'll save a couple of cents a month with the AX850... The performance of the HX850 and AX850 is pretty identical so unless you like the looks of the AX better or want a slightly quieter fan, it isn't worth it.
Discussion Starter · #12 ·
Thank you! And to all of you big help
. All deserve rep, Fast replies less stress Now that is 80plus gold >.>
Discussion Starter · #13 ·
AX850 has a quieter fan?
The HX is at $145 AR so it's closer to a $40 difference.
The fan stays off until a certain amount of load/temp threshold is exceeded.
· Premium Member
Firstly a few doa reviews is nothing to be alarmed by all the corsair psu's I've had are solid.
As for the 850 what kind of rig are you planning to run on it? 850 is really a pretty damn big psu. unless you are looking at 3 way gpu's I would suggest dropping to a 650-750w and put the extra money into quality or some other parts.
· Premium Member
I would honestly choose the HX850 over the AX850, I've seen a lot more AX PSU's to have squealing noise on the capacitors, which can get pretty annoying sometimes when you put heavy load on your computer.
Both are great PSU's, and AX850 has a quieter fan, but then again I've seen more squealing AX850's than HX850's, I'd go for the HX850, unless you really like the design of the AX850.
· Premium Member
Originally Posted by obsidian86
Hx 850 is also gold
No, the Corsair HX850, while it is as good as the AX850, it is +80 Silver rated since it was a bit on the limit for being +80 Gold rated, but can still be considered a +80 Gold PSU, so you're kinda right after all
The efficiency of both units are very close. The AX850 barely scrapes the Gold surface, while the HX850 almost touches Gold.
1 - 20 of 58 Posts
