1 - 20 of 426 Posts
(unofficial till a mod makes it official)<br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2635076/"><img alt="" class="lightbox-enabled" data-id="2635076" data-type="61" src="http://www.overclock.net/content/type/61/id/2635076/width/200/height/400/flags/LL" style="; width: 200px; height: 142px"></a> <b><span style="font-size:36px;">909 OWNERS CUB</span></b><br><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2635077/"><img alt="CREATOR: gd-jpeg v1.0 (using IJG JPEG v80), quality = 100" class="lightbox-enabled" data-id="2635077" data-type="61" src="http://www.overclock.net/content/type/61/id/2635077/width/500/height/1000/flags/LL" style="; width: 370px; height: 460px"></a><br><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2635078/"><img alt="CREATOR: gd-jpeg v1.0 (using IJG JPEG v80), quality = 100" class="lightbox-enabled" data-id="2635078" data-type="61" src="http://www.overclock.net/content/type/61/id/2635078/width/500/height/1000/flags/LL" style="; width: 370px; height: 460px"></a><br><br><br><br><span style="font-size:16px;">reviews</span><br>
<a href="http://www.hardwareluxx.com/index.php/reviews/hardware/cases/36691-reviewed-in-win-909.html" target="_blank">http://www.hardwareluxx.com/index.php/reviews/hardware/cases/36691-reviewed-in-win-909.html</a><br><br><span style="font-size:16px;">Owners</span><br>
maybach123<br>
jarramundi<br>
wmandra<br>
MaN227<br>
gekkotype<br>
Sutton<br>
Tlakma01<br>
kaptanedi<br>
(if you own the case please post a picture with your username and we will add you to the list)<br><br><span style="font-size:16px;">Specs</span><br><b>Case Size</b> Full Tower<br><b>Material</b> Aluminum Tempered Glass<br><b>Internal Drive Bay</b> 3.5” / 2.5” x 4 2.5” x 6<br><b>M/B Form Factor</b> E-ATX / ATX / Micro-ATX / Mini- ITX (Max : 12” x 13.4”)<br><b>Power Supply</b> ATX 12V, PSII Size and EPS up to 220mm<br><b>I/O Port</b> USB 3.1 (TYPE-C, 19-pin Connector) x 1USB 3.0 x 3 HD Audio<br><b>I/O Expansion Slot</b> PCI-E Slot x 8 Supports High-End Graphic Card (Length up to 320mm , Height: 180mm)<br><b>Thermal Solution Air Cooling Supports</b><br><span style="font-size:10px;">Front - 120/140mm Fan x 2<br>
Middle - 120mm Fan x 1<br>
Rear - 120mm Fan x 3 or 140mm Fan x 2<br>
Bottom - 120/140mm Fan x 2<br>
Water Cooling Supports<br>
Front - 280mm Radiator (Height up to 35mm)<br>
Middle - 120mm Radiator (Height up to 35mm)<br>
Rear - 360mm Radiator (Height up to 60mm)<br>
Bottom - 240mm Radiator (Height up to 35mm)</span><br><b>CPU Heatsink</b> Supports Maximum CPU Heatsink up to 175mm (CPU Die Surface to Sid Panel)<br><b>Dimension (HxWxD)</b> 540 x 231 x 575mm 21.3" x 9" x 22.6"<br><b>Net Weight</b> 17 kg<br><b>Gross Weight</b> 20.6 kg
We can't wait to see all of the beautiful 909 builds! <img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif">
Discussion Starter #4
<div class="quote-container" data-huddler-embed="/t/1580622/inwin-909-owners-club#post_24624364" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>In Win Insight</strong> <a href="/t/1580622/inwin-909-owners-club#post_24624364"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
We can't wait to see all of the beautiful 909 builds! <img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif"></div>
</div>
ya i have the case and i couldn't be happier cant wait till pascal going to be fully watercooling it (with black nickel tubing)
<div class="quote-container" data-huddler-embed="/t/1580622/inwin-909-owners-club#post_24625505" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>maybach123</strong> <a href="/t/1580622/inwin-909-owners-club#post_24625505"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
ya i have the case and i couldn't be happier cant wait till pascal going to be fully watercooling it (with black nickel tubing)</div>
</div>
<br>
The nickle tubing will definitely look sharp! <img alt="thumb.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/thumb.gif">
Sign me up!<br><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2640161/"><img alt="" class="lightbox-enabled" data-id="2640161" data-type="61" src="http://www.overclock.net/content/type/61/id/2640161/width/500/height/1000/flags/LL" style="; width: 500px; height: 333px"></a>
Discussion Starter #7
<div class="quote-container" data-huddler-embed="/t/1580622/inwin-909-owners-club#post_24630722" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>jarramundi</strong> <a href="/t/1580622/inwin-909-owners-club#post_24630722"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Sign me up!<br><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2640161/"><img alt="" class="lightbox-enabled" data-id="2640161" data-type="61" src="http://www.overclock.net/content/type/61/id/2640161/width/500/height/1000/flags/LL" style="; width: 500px; height: 333px"></a></div>
</div>
<br>
awesome another member love the look of your build very sharp
Meep
<a data-huddler-embed="href" href="/u/440592/maybach123">@maybach123</a> just fyi, There's supposed to be a space between In and Win, its causing it to not show up when people search for In Win 909.<br><br>
Also capitalizing the first letter of every word can make your title look a little better.<br><br>
In Win 909 Owners Club
<a class="bbcode_url" href="http://www.overclock.net/u/481953/jarramundi">@jarramundi</a> is that the EK Predator 360 AIO? using their vadar fans? or what fan?<br><br>
if I am correct on this assumption is it also correct you are using push/pull on that rad? as intake or exhaust?<br><br>
how do you find the temps? I see you have 2 front 2 bottom intake and the 4 120's in the rear.<br><br>
this is the aio i was looking at. I even have the same gpu <img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif"><br><br>
any insight is appreciated , particularly to air flow and cooling. very curious about the front fans and how much air they move. thinking with the 2 bottom fans that the front don't do much , that the bottom would have to be blocked for front fans to pull more air from the bottom.<br><br>
any issues with rear I/O connections and managment/clearance with rad fans?<br><br>
looks good bro <img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif">
<div class="quote-container" data-huddler-embed="/t/1580622/in-win-909-owners-club#post_24667498" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>MaN227</strong> <a href="/t/1580622/in-win-909-owners-club#post_24667498"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br><a class="bbcode_url" href="http://www.overclock.net/u/481953/jarramundi">@jarramundi</a> is that the EK Predator 360 AIO? using their vadar fans? or what fan?<br><br>
looks good bro <img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif"></div>
</div>
<br>
Hey mate,<br><br>
Here is the buid on PCPP<br><br>
<a href="http://au.pcpartpicker.com/b/4Hm8TW" target="_blank">http://au.pcpartpicker.com/b/4Hm8TW</a><br><br>
It most certainly is the Predator 360 AIO, i am using it in push as an exhaust. It was very fiddly to get in, in that combination and it is not an overly nice fit but does the job.<br><br>
There are 4x Noctua NH14 IPPC 3000rpm fans in the front, an a 120 Noctua NH12 IPPC 3000rpm in the middle as well as the 3 EK Vardar fans on the rad.<br><br>
The airflow in the case didn't seem to be too bad for the amount of time i had to get in going and to play with it. I decided to use the fans to direct the airflow in the way that In Win marketed the case, bottom 2 fans pulling up and front 2 pushing towards the rear.<br><br>
The 980ti HOF is a great card, heavy as all hell, so mine sags considerably. I will be fixing this when i am home from work next.<br><br>
The rear I/O connections can be a pain in the arse as yiu have to take the back side glass panel off, however its not a huge deal.<br><br>
As for case temps, i will have to get back to you between tbe 14th and 28th of december, as i am currently working until then (i worm away from home on a long roster), so if you are happy to wait i can provide some better photos for you.<br><br>
Hope this helps a little
Meep
<div class="quote-container" data-huddler-embed="/t/1580622/in-win-909-owners-club#post_24669949" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>jarramundi</strong> <a href="/t/1580622/in-win-909-owners-club#post_24669949"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
The 980ti HOF is a great card, heavy as all hell, so mine sags considerably. I will be fixing this when i am home from work next.</div>
</div>
<br>
Why didn't you go for a 980TI that has an EK waterblock available? You could've gotten a pre-filled version to go with your Predator that way.
thank you, I have no issues waiting. not in a hurry to spend 450 on this case just yet with holidays coming.<br><br>
I'm also going to guess that most people are like me thinking their asking price of 450 is rather high, I don't actually see it staying that high for very long. and the lack of people in "the owners club" speaks volumes to the general feelings of the public about this case. concerns about lack of airflow and its very high price. as there is no denying it is one sexy case.<br><br>
I bet this case will be much better received and much more sales once price drops to 350$ and below. yes there are a few exceptions to case price but 99% of all cases sold will come in under 450$, even under 350$ for that matter. lack of sales though the end of this year will make them see the light on pricing this case too high. I'm holding out till in win wise up and lower the price.
uh oh.
I'm in the market for a case right, I need to put that R4BE+4930K+980 KPE that are sitting in a box into a case. The 909 seems to be a beautiful candidate (even more since I want to do a full black build for a change).<br>
Is there some ppl that did watercooled build with EAT-X board, I've seen one on google with an X99 Deluxe but not crowded with radiator.<br>
I'd like to see one with 3x280 (or 1x280 and 1x240) and a 360 in there. If anyone ever seen that, can you link the pics/log, thanks.
Discussion Starter #14
<div class="quote-container" data-huddler-embed="/t/1580622/in-win-909-owners-club/10#post_24681106" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Kimir</strong> <a href="/t/1580622/in-win-909-owners-club/10#post_24681106"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
I'd like to see one with 3x280 (or 1x280 and 1x240) and a 360 in there. If anyone ever seen that, can you link the pics/log, thanks.</div>
</div>
i own the rampage 4 black edition and you should be able to watercool it no problem it sits about 3 inches above the intake and five inches back from the front of the case although i wouldnt put a radiator in the front vertical area because it only takes in air from the two slits in between the glass and metal. hope that helps
Sneak peek of my 909 build...<br><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2653539/"><img alt="" class="lightbox-enabled" data-id="2653539" data-type="61" src="http://www.overclock.net/content/type/61/id/2653539/width/350/height/700/flags/LL" style="; width: 350px; height: 285px"></a><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/2653540/"><img alt="" class="lightbox-enabled" data-id="2653540" data-type="61" src="http://www.overclock.net/content/type/61/id/2653540/width/350/height/700/flags/LL" style="; width: 350px; height: 291px"></a>
Meep
<div class="quote-container" data-huddler-embed="/t/1580622/in-win-909-owners-club/10#post_24681294" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>wmandra</strong> <a href="/t/1580622/in-win-909-owners-club/10#post_24681294"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Sneak peek of my 909 build...</div>
</div>
<br>
Could you edit you post with the images uploaded with the image function in the editor instead of download links?
<div class="quote-container" data-huddler-embed="/t/1580622/in-win-909-owners-club/10#post_24681320" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Gilles3000</strong> <a href="/t/1580622/in-win-909-owners-club/10#post_24681320"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Could you edit you post with the images uploaded with the image function in the editor instead of download links?</div>
</div>
<br>
done. sorry about that.
I'm a bit curious why you have to move the fans to the other side of the radiator when using the EKWB Predator 360. I was myself thinking about getting this AIO for this specific case, but I'm having second thoughts now that I see there seems to be a problem.<br>
Could someone elaborate a bit on why it did not fit? I understand why you need the extra long screws when moving the fans to the other side, but why move the fans in the first place?
I have the case and can someone point out to me where i can install an optical drive. Thanks
<div class="quote-container" data-huddler-embed="/t/1580622/in-win-909-owners-club/10#post_24728884" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>grassy</strong> <a href="/t/1580622/in-win-909-owners-club/10#post_24728884"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
I have the case and can someone point out to me where i can install an optical drive. Thanks</div>
</div>
<br>
There is no 5.25" drive bays on the In Win 909. So unless you do some serious modding, I would say you need to have an external optical drive for it.
1 - 20 of 426 Posts
